I have built my very first foam plane using the FT speed build kit for the Nutball, but it is yet to get off the ground. One thing after another keeps going wrong, so I am learning fast about things that should have been obvious to an experienced RC flyer but were not to me. The latest issue is that whenever I try to take off the motor falls out of the motor mount. I am using the HobbyKing "HexTronik 24gram Brushless Outrunner 1300kv" (http://hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=48047), which has these two tiny screws that are supposedly used to keep the motor attached to the motor mount (image attached), but no matter how much I tighten these screws these do not seem to be tight enough and end up loosening when the throttle is increased.
Is there a trick that I am missing to securing the motor shaft to the motor mount?
Also, the last time the motor shaft fell out of the motor mount, i lost one of the two screws - can these be purchased separately or do i have to get a new motor now?
If I get a new motor, are there ones that do not have this problem and perhaps use a different method of securing the motor to the shaft?
Thank you all very much for any of your suggestions.
