Hi guys, so I'm building a fixed wing UAV with a tractor configuration. As part of my OSC, I have to write a pre-flight checklist. This is my first time building a UAV so I'm quite clueless. I'm reading that the propeller has to 'face' the right direction in order to generate proper thrust w/ less noise etc - this I understand.
However, I'm also reading that the motor and propeller must spin in the correct direction and I don't understand how to know which direction the motor/propeller should spin in? I'm reading this a lot for quadcopter cases but i'm not sure what the deal is for a fixed wing UAV...do the motor and propeller always spin in the same direction as each other? i thought they do but now im not so sure. Also, as part of a pre-flight checklist, should I include checking if the motor and propeller spin in the correct direction and also checking if the propeller is 'facing' the correct way? is it possible to check the motor spin direction on a fixed wing uav immediately before flight or is that dangerous or something?
Any help would be appreciated, thank you so much
