Anyone having trouble with the ft alpha
TopGun2105
Hi my plane has been giving me a little trouble I have been flying the ft alpha and the motor seems to be getting super hot so hot that I couldn’t stick my finger on it and I’m convinced that it puffed up my battery by a tiny bit and I is also pretty warm and I only have a 2-3 minute flight and they are still fairly new I’m running a 850mah 30c 3s lipo with a 2204-2300kv motor and a 5045L three blade propeller the plane is also a little under powered I’ve checked the propeller orientation with the numbers facing the direction that the plane is going
Ratcheeroo
I built 2 of those and kind of had the same issues. I also found it to be underpowered but in the end I figured that I was overweight and that was causing the issues. I tried the Mini FT-22 after that with the same motor and battery and it was much better, and a much simpler build.
TopGun2105
TopGun2105
Did the planes controls also feel slow because I flew with the recommended throws and I was pooping my self I couldn’t control the plane so I gave it around 45 degrees and even then it took me about one second just to do a roll
TopGun2105
TopGun2105
Ratcheeroo
yep, as much as I wanted I just couldn't get that plane to go right
Gray Harlequin
I have both the charlie and bravo wings flown on an alpha fuselage. I haven't had the motor heating issues, but they do feel a bit underpowered (possibly the prop). I will agree totally with the lack of control authority. I have my elevons at max travel to get decent control. I will say that the much narrower bravo wing rolls much faster due to the shorter wingspan. One thing that I noticed was that it was nearly impossible to fly inverted. After running the dimensions through a CG calculator, the CG that FT recommends seems to be too far forward. I moved it back to just in front of the servos and it flies better.
TopGun2105
I’ll try that thanks
Matthewdupreez
Your prop is too big. You should try a 6030 2 bladed prop. That should sort out all your issues
Ratcheeroo
So you are telling him his prop is too big and you want him to use a bigger prop? Sounds like sound advice :unsure::unsure: not. Ran both of mine on 6x4 props. Any other suggestions?
FlyerInStyle
i think he meant that the pitch of the prop and the blades are too much for the motor.
Matthewdupreez
so he's running a 5045 tri blade prop (equivalent to about a 6545 2 bladed prop).... im suggesting he goes to a 6030 2 bladed prop...
will.fred.tx
I beefed up the power on mine & it screams! No problems and getting 86 mph calculated speed in level flight at full power.
FT Radial 2205 2300kV motor
50 amp ESC
850 mA 4s 100C lipo.
6x4.5 e prop (2 blade)
Added a little weight to tail to balance out the 4S pack.
I would not recommend and higher propeller pitch or a 3 blade prop as I feel this setup is at the max of the envelope without burning up the motor.
I'll paste the YouTube link for the Maiden flight below.
