joelmartinez
Hi all ... first time poster, but long time flitetest show fan. So I've built my first quad, everything seems to have gone relatively smoothly, other than the fact that the motors don't spin when instructed (I know, that might be problematic)
The quad I've put together uses an Seriously Pro F3 flight controller (with cleanflight), and motors/ESCs from the this flitetest power pack. Got everything soldered up and connected, and it *looks* like it should be working, and indeed, I can arm it and see the tx input from the receiver in the cleanflight configurator. **Unfortunately**, the motors do not spin; neither from tx throttle input, or by the motor override in the cleanflight configurator.
I was wondering if anyone could give me some troubleshooting tips/ideas on what I could check.
Things I've tried so far:
- Verified all solder points for ESCs ... looks good as far as I can tell: https://i.imgur.com/XSmqudo.png
- ESCs plugged in in the correct order 1-4: https://i.imgur.com/cRC9p4A.png
- The ESCs definitely have power, cause they make the motors buzz when I plug the battery in short vid of sound. However, I will note that it's not the exact same sound that I've heard from other quads ... if that makes sense. Not sure if that's a hint that something isn't plugged in right.
- Configuration of ESCs/Motors in cleanflight: https://i.imgur.com/RY6mf4o.png
- Attempted to calibrate the ESCs (as shown here), but they don't seem to be responding to the calibration.
Not really sure what else to test, but any tips anyone can offer about what to test, or how to troubleshoot would be greatly appreciated. Thanks!
note: I've x-posted this post to /r/multirotor so you can see any other suggestions/troubleshooting that might occur over there: https://www.reddit.com/r/Multicopter/comments/3jak9f/motors_not_spinning_up_help/
