The tool I use is called "Unfold".
I am still using the 2014 version of Sketchup because at one point I tried to update and the installer crashed so I just stuck with the 2014 version. So I can't comment as to whether the "Unfold" tool will work with your version of SU.
I tried searching for this tool this morning and can't seem to find a downloadable version (maybe because it's so old).
Attached is the .rb file for the tool. There does not seem to be any attribution to an author in the source (which is weird) so I think it's okay to share here. Just extract the zip file and put the .rb file into your tools folder, or wherever you put your plugins for your version of Sketchup. You will need to re-start Sketchup after adding the file to your Plugins folder.
To use the tool, select it from the Plugins menu and then just click on each surface in order to unfold the piece. As TeaJR66 said, all the adjacent faces need to be oriented the same way to avoid weird folding (but looking at your model you don't seem to have that problem).
A trick I use (read somewhere on the web) is to first create a flat rectangle on your model, then start unfolding your piece. Once the piece is unfolded (but it will not necessarily be flat on the ground plane), perform one last unfold operation by clicking on the flat rectangle - this makes the piece lie on the ground plane.
Hope this helps.
DamoRC
View attachment unfoldtool.zip
Hope this helps.
DamoRC
