So I put the BatBone on hold while I wait on some more ESC's to come in. The SkyWalker Quattro was over kill and over weight for the "Bat". In the mean time since I had spare motors and parts... I built the H Quad using scraps from my wood pile and 1/8" ply I found at a craft store. Break down of the build:
Suunsky A2212 1350kv motors
Skywalker Quattro 4n1 20A ESC
APC 8x6 and 8x6P props
EFlite 1800Mah 3S
APM2.6
Turnigy 9X TX/RX
Loaded the X-Quad firmware and was able to get very twitchy hover. Decided to try the APM's autotune feature. Not bad except I misunderstood how loiter mode worked and kept fighting the throttle for hover. Ended up with a spectacular pinwheel crash and broken booms. 2nd attempt same results. So... I figured why not use the Knuckle quad plans and keep it the same size without using glue so I can replace the booms. I give you my oversized Knuckle H:
Flight times are about 5 Minutes. So being a noob to this how do I increase the flight times? Any recommendations for improving my build?
I hope the wife doesn't catch me using the picnic table as my launch pad....
EFlite 1800Mah 3S
APM2.6
Turnigy 9X TX/RX
