L Edge
Have you ever had a project that has kicked your butt? I chose the VTOL bi-copter approach 11 years ago, 7 years ago, 1 year ago, and now. Vibrations, stability, and lack of experience with the software got the best of me time after time. Well, I am back at it and making progress.
Always looking for a VTOL plane that doesn't exist, decided to make one where there are no physical surfaces for aileron, elevator or rudder control and yet fly. So this is it.
Notice the two servos, that is the key to horizontal flight. To have pitch, both servos go up or down, roll has one servo go up and the other down, and yaw uses differential thrust by changing RPM's.. Does it fly and can it take off vertical? Heck yes, with ease. Can it have a controlled takeoff and land? That's the problem. Forward flight is rather easy, hovering(wind) and landing, not so.
Can a gyro work? No, because there is a vert to horizontal which is called the transitional stage. This allows you to maintain a lift/thrust hovering/flying conditions at all times to control the aircraft.
11 years ago, Open Aero VTOL V1.6 software using a KK2.1 board with help available. Over time, it dropped out of production so only help was booklet. Anybody who has explored software and puts the wrong value(s), it ain't going to work. So struggle it is until "eureka", so now I hope to go one step forward and stay, not 2 back.
If you look at the vert picture(ship is called EYESPY), to lift off and hover, you add throttle and hold it fixed once it is off ground.
To pitch down, it moves away from you, pitch up, it comes to you. (Both servos move same direction)
To rotate about itself(roll), right aileron brings the left corner counterclockwise. (Left servo comes at you, right moves away)
To move plane to the right(yaw), the rudder is pushed to the right. (Remember, if throttle moves a click less, down you drop) Servos don't move, right motor decreases)
So while I practice in the cellar hovering( finally solved P,I,D's) and now tweaking, here is horizontal flight showing it flies, even with gusts.
Still have transition to cover, should be no problem going to horizontal, but other way around controlling decent with wind.!!!!!!
