Morgan
So I had a micro setup but just hadn't built anything much with it so I decided if finally give building something pretty small a go. This is I came up with . A 77% sparrow . For electronics I had a 1106 red bottom with a 20 amp arris nano esc ,3.7 gram servos and a 450 mah 3s. I used 3mm dollar store foam board which i actually use for most smallish sized planes . When I went to maiden it I was pleasantly surprised. Sparrows have a reputation for being difficult to launch but I had no difficulty at all and I still have given it a single click of trim . It easily has enough power for unlimited vertical and to be reasonably quick but can still slow way down . It's nothing terribly spectacular but I
figured I'd share it in case anyone was considering a similar plane.
