Pumpkin drop event
Naze 32 - No response from the bootloader, programming failed - error message
sebrob7
Hi,
I bought a Naze 32 on the net. I try to Flash the firmware (which is the first step in the config presented by Josh on the article for the quad) but i got this message " No response from bootloader, programming FAILED". :(
I'm new, it's my first quad, what should I do? Do you have an easy answer, kind of step by step (I'm french).
Thank you :)
makattack
Winter is coming
If you have installed the proper USB drivers for your operating system, if necessary, the next likely step is to try a different USB cable. Many inexpensive charging cables lack the necessary data lines.
Bon chance!
PHugger
Church Meal Expert
#5
You still need to install the USB driver or else your Mac won't "see" the Naze board.
You can download it here-
https://www.silabs.com/products/mcu/Pages/USBtoUARTBridgeVCPDrivers.aspx
If this still does not work you'll need to obtain a USB cable that can handle the data connection.
As Mak said - they are Not all the same......
Most charging cables that come with cell phone are not capable of making a data connection.
Best regards,
PCH
PHugger
Church Meal Expert
#7
Did you install the appropriate driver?
If you did, what type of cable did you use?
If it was one you got with a cell phone it probably won't work.
I would buy a new one. Try Monoprice or Amazon.
You want a "real" USB cable not an OTG charging cable.
Best regards,
PCH
