Yusernaym
I picked up a kit for an Iflight Flycat 270 from my local hobby shop yesterday, along with everything needed to complete it. The main kit was heavily discounted due to it being very old, so I got out with a frame, motors, speed controllers, flight controller, receiver, props, solder, and heat shrink for less than $150. I got started on the build yesterday, taking my time and following guides. Today I got it to the point where I should have been getting ready to set it up, flash firmware, bind the receiver, and maybe even test, but I hit some snags. First was that I got the wrong receiver the first time around. It used Spektrum's new weird sort of serial protocol, which is not supported by the Naze 32 rev5 that came with the kit. I exchanged that for the right kind of receiver, and had the shop's quad specialist look at my wiring. I had all three leads from every opto ESC connected to the pins of the flight controller. According to what I had seen from a cursory search last night, that was fine, but it seems like a case-by-case kind of thing, as there's a chance my ESC's throw unregulated battery voltage down that lead, which very well could have fried my flight controller. None of the lights on the FC board react in any way to a battery or usb cable being plugged in, and the Betaflight configurator doesn't connect to it, even with the boot pins shorted.
Now I'm left with a quad that looks great, in my opinion, but definitely needs some work. I didn't expect this to only take a couple of days, so I'm not surprised that it's not done, but I was hoping not to spend more than necessary, and I might have killed my flight controller. I'll add an image of the current wiring so some of you who know what you're doing can give me tips. I should preface it by saying the reason the connections look so bad is that the insulation on the esc wires is very heat sensitive, and it got ugly while I was soldering. Also, the tape on the red wires is to keep them from shorting on anything, and I know it's not pretty.
