theugleeflyer
hey all. Here's the info.
Quad: Arris 250b
http://www.arrishobby.com/arris-xsp...bo-w-f3-flight-controller-us-warehouse-p-3451
(I swapped out the flight chip with a Naze 32 bought from the flite test website because I accidentally fried the first one.)
Receiver: Spektrum AR610 6CH sport receiver
Transmitter: DX6e
PROBLEM: Tried installing firmware through the cleanflight app. At first I used v1.14.2 - Naze - 2016-12-30 3:15 (stable)
for some reason i was not able to bind the receiver with the transmitter. i checked my receiver to see if it was connected correctly with the flight chip. i followed the directions from https://www.youtube.com/watch?v=aFf3ybXDuYs&t=798s. i even tried putting the chords on the positive pins. Still couldnt bind. I then put the chords back on the negative pins in order.
Was not sure if it was the version I used so I tried using an older version.
I tried v1.14.1. set it to FULL CHIP ERASE >> Load Firmware [online] >> flash firmware
it worked.
I then tried again with full chip erase off.
It then read "No response from the bootloader, programming: FAILED"
At this point, i had no idea what i was doing. i went back and forth between the versions trying every possible combination. nothing worked. i made sure not to go beyond v1.11.0 though.
now i cant connect via usb or flash the firmware.
please help
Quad: Arris 250b
Transmitter: DX6e
it worked.
please help
