On Choice
All of you electric fixed-wing veterans out there - I am in need of your wisdom.
I'm looking for a plane that has the following characteristics:
- Very Durable
- Relatively Easy to Repair
- Very Stable
- Capable of Handling 15-20 mph Winds Very Well
- Capable of Carrying Battery/Batteries Weighing 500g
- Slow
- Easy to Handle
Your recommendations are very much appreciated.
I'm a newbie as well with little experience however, I've been looking at the Ares Gamma 370 Pro RFR. The writeups on it seem quite favorable and it will handle a 3S 1350 battery. The plane I ordered is a clone, it differs in only two aspects. The fuselage is an inch shorter and the ESC is a 20 A vice the 18 in the true Ares. There are several reports of the ESC being prone to failure in the Ares, so I'm hoping the Chinese knockoff with a 20A ESC escapes those problems. As everything else seems to be the same as the HobbyTown version, spares should be easy to locate. I don't know how it would do in those winds, but there are many reports of the Ares handling 15 MPH winds with little problem.
The stock props are very fragile and landing without having to replace a prop is considered a major achievement. Most recommendations are for an 8x6 slow flyer for trainer flights. The Ares is capable of some aerobatics as the 370 does have the power to do almost anything. Most of the mods seem to do with rearranging the landing gear either by reversing the battery box or strengthening the actual gear to cut down on the nose over tendencies of the plane. All-in-all, if you can believe the Internet reports is this is a great intermediate to advanced plane that is easy to repair and with inexpensive parts.
I just bought the DX6 with the AR610 included so I have my radio. Now all I need to do is get them programmed. Hopefully I'll find someone to buddybox with when I've got everything together.
