New Quad Build Please Check Guys
karan538
Hi guys, I'm new to this forum.
I've had a great interest in RC, bought an Ar drone 2.0 a year ago and love it. After watching flitetest I was inspired to build my own quadrocopter. I have bought all these parts and am awaiting delivery.
Hobbyking KK2.0 Multi-rotor LCD Flight Control Board $29.99ea $29.99
Turnigy nano-tech 3300mah 3S 25~50C Lipo Pack $26.72ea $26.72
HXT 4mm to 6 X 3.5mm bullet Multistar ESC Power Breakout Cable $4.80ea $4.80
NTM Prop Drive Series 28-30A 750kv / 140w $14.99ea $59.96
TURNIGY Plush 25amp Speed Controller $11.77ea $47.08
Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 1) (v2 Firmware) $54.00ea $54.00
Slow Fly Electric Prop 1045R SF RH Rotation (4 pc) $3.07ea $3.07
10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) $3.96ea $3.96
Turnigy Battery Strap 330mm $1.59ea $3.18
M3X10 Nylon Screws (10pcs/bag) $0.77ea $1.54
NTM Prop Drive 28 Series Accessory Pack $1.85ea $7.40
Turnigy Talon Carbon Fiber Quadcopter Frame $33.41ea $33.41
5.6mm x 12mm M3 Nylon Tapped Spacer (10pc) $0.97ea $0.97
10x4.5 SF Props 2pc Standard Rotation/2 pc RH Rotation (Red) $3.14ea $6.28
M3 Nylon Nut (10pcs/bag) $0.69ea $1.38
Super Bright 3Watt White LED Lamp with Aluminium Heatsink $0.99ea $0.99
Turnigy 5mm Heat Shrink Tube - RED (1mtr) $0.35ea $0.35
ES-8046/6G 4 Min Clear Epoxy Glue $0.99ea $1.98
Peel-n-stick foam tape. 10x5inch 4mm thick $1.49ea $1.49
Cable Ties - White (300mm) (50pcs/bag) $1.51ea $1.51
XT-60 to HXT 4mm Battery Adapter Lead (2pc) $3.80ea $3.80
Turnigy Accucel-6 50W 6A Balancer/Charger w/ accessories $22.99ea $22.99
HobbyKing Power Supply 100~240v 5A $9.49ea $9.49
Extra Size Cardboard Box and Packing 183g $0.00ea $0.00
What I want to be able to do with these is sit down, Build and be able to fly right off
So can you guys please tell me if there's anything missing that I will need or if something does not fit. I think I will need extra bullet connections for the speed controller as mine does not come with them
Will I be able to fly right off, I have all the tools.
Thanks guys
PaulT
karan538
#4
Thanks guys.
So is everything alright in the list. Will it all fit lovely jubbly? lol
Edit: I will try out these plush 25's, I'll buy some other ones and keep them on standby incase these dont work
Cyberdactyl
Misfit Multirotor Monkey
#5
One thing I would throw out there is to consider doing without the, "HobbyKing Power Supply 100~240v for $10" ... IF you have access to an old PC power supply. Not only do you get a 12V power supply, but you also get a 5V and 3V as well. And the bonus. . .as you may have noticed, is a ton of 12"-18" 20 gauge wire, which I have used in abundance. . . :p
