New R84 Receiver, no LED when trying to bind
TexEll
Hello all, my son has just gotten a new Tiny Tutor starter bundle as his first RC plane. He's built the plane, but we're having a heck of a time divining how to bind the R84 receiver to the RadioMaster Pocket radio.
After searching these forums, we've learned that we're to hold down the bind button on the R84 while connecting the battery, after putting the RadioMaster in bind mode. Evidently the LED on the R84 is supposed to flash in some meaningful way, but ours does not light up at all. Might we have a defective receiver? Is there some other way to convince it to light up?
Thanks for any help. We're both new to this and are getting frustrated with this first kit.
CrshNBrn
I had the same issue with recievers when I first started. While I'm sure you'll get other suggestions and advice, I'd recommend you check the polarity of your wires into your receiver. Make sure those are correct. Keep trying and good luck.
Bricks
Normally the receiver is put into bind mode then the transmitter is turned on. As mentioned above make sure your wires are plugged into the receiver correctly usually signal white or yellow is to the top of the receiver and plugged into the correct port.
On this page is a video of how to bind the R84 v2.
https://www.radiomasterrc.com/products/r84-receiver
hammock007
I have been following an instructional video for the mini-explorer and it contains detailed information for connecting and binding the R84. Maybe it would be helpful to you:
