Solved Need help binding radiomaster pocket to r84 receiver
rowboat
Hey y'all,
Complete beginner here. I bought the complete build kit for the FT tiny trainer which comes with a radiomaster pocket controller and radiomaster r84 receiver. I cannot figure out how to bind these. All the videos online seem to show the receiver with an LED that comes on when in binding mode, but no matter how long/how many times i press the button on the receiver nothing seems to happen. Any help would be very much appreciated.
nathaniel2011
did you try holding the bind button while plugging in the battery? That worked for me on my aura bord/lemon rx dsmp satellite receiver.
Ben2194
Hi! Also having the same issues... I'm able to get the receiver into bind mode via holding the pushbutton while plugging it in to the battery, however, not too sure what to do next. Im using FrSkyD subtype D8 and I'm hitting bind whenever 3 singular flashes show up according to this vid "
" but it's not working... any help is appreciated! Thanks!
AIRTREADFPV
I have had great success binding my new R84 and R86 recievers to my Taranis. This is my process:
-turn on radio
-make new model
-put radio into bind mode
-hold bind button on reciever
-plug in battery while holding
-keep holding until red light flashes
-then push bind button in radio to complete
-i then power cycle and has worked for x10 new units!
good luck, hope this helps
Ben2194
I GOT IT! I had to go into sys -> hardware -> then under internal RF i had to select multi (it was set to csrf or smtn like that).
Before this, under status would read no telemetry but now it has aetr.
Thanks!
Pradeep
I am currently having the same issue,
I am a beginner and the plane I am building is FT Tiny Trainer,
I have done everything I could including the other posts and scattered across the internet but still can manage to get the lights to show up. Is there any other way that could help in fixing this issue?
jbreiden
I am also completely new, working with the FT Mighty Mini Tiny Tutor starter kit. I think I understand what to do on the receiver. I am completely stumped for what to do on the transmitter. I would deeply appreciate the exact sequence of button presses required to initiate binding.
So far, I've tried "SYS :: ExpressLRS" and got stuck with a perpetual loading message, perhaps because this transmitter is not the ELRS version? I've also tried "MDL :: Pocket :: PAGE>" which gets me to a SETUP section but looks nothing like the one in the manual. The manual shows an option for binding, and instead I see stuff like Timer1.
The video assembly tutorial is with a different transmitter so it is not helping me.
jbreiden
I cannot emphasize enough how little I know about this stuff. The label on the transmitter box says "Pocket CC2500". This transmitter was included with the starter bundle along with the R84. Is there a tutorial video, or beginner friendly documentation?
