johnreto
Then how would you describe how they are to props?
Any structure made of metal will be grounded. This will make it so it acts as an antenna with a higher gain due to its size and will absorb the signals before they reach your fpv gear if you put it between you and your craft. Light poles that use high current AC (stadium/field lighting) will have a magnetic field around the areas where that high current flows. That can scramble or reflect radio signals. They also usually have huge metal reflectors that are grounded and they will be like antennas and absorb radio signal and sink them to ground. Expect the signal loss in certain areas and it becomes a minor issue if you know when you power loop that light fixture you lose signal at this angle for a brief second and just power thru the maneuver like normal most times you will be fine. Just know your gear and that only comes from continual use under varying situations.
Most of the FPV things you need to know are common sense once you understand how it all works. There are simple things you can do to avoid most of it. First off is to look at and PAY ATTENTION to your surroundings before you fly. That means putting away your cell phone and any other distractions that are not involved with flying your craft. Flying should be your ONLY focus when you are in the air. Second is to not just toss your craft in the air and see how far you can go. Start close and slow and work your way outwards.
If you fly the same place for practice you will learn over time what areas to avoid and these checks won't need to be done all the time. If you are flying a new area you should be starting your session every time like this. Also do NOT go by "My buddy flys here all the time with no issues" mentality. Each piece of gear is just a tiny bit different and will act in different ways to various things. Just be smarter then the gear you are using and make sure you know its quirks and limitations.
After that the flying becomes seriously fun because you can relax and trust your gear. If you do not trust your gear then you should not be flying in that place or at the very least adjust what you are doing so you can trust your gear. Simple things like an antenna change or a channel change can make far more difference then just cranking up the power.
good thing we dont have that many light poles (none) where i plan to fly hehe. Mostly just BIG vast grassy fields.
interestingly enough i'm pretty much one of the only rc/fpv flyers here, just one other guy
here that flys (he's got 20+ planes in the cellar
most of the time i fly at the same place.
which antennaes give the best and farthest reception?
when i receive the gear i'll have to figure out how to change the channels
thnx
