New to FPV
jurt
Hello, I recently purchased a drone and was able to bind my transmitter and my goggles but when i plug my drone into beta flight my transmitter doesn't seem to be working I'm stuck and don't know what else i have to do
the drone is the GEPRC cinelog35 v2 and im using a radiomaster boxer elrs2.4
Foamforce
Are you saying that because the motors aren’t spinning up? When it’s connected to Betaflight, the motors are disabled for safety. If you go to the receiver tab in Betaflight and move your sticks, do you see the movement on the channel displays? If you do, then to enable the motors you go to the motors tab and click the “Motor test mode notice” slider in the bottom right. You also need to also plug in a battery for the motors to spin up.
Send pictures of your receiver and serial tabs. Sounds like a misconfiguration of the serial/RX.
jurt
in betaflight I can get the motors to spin up no problem but I when I goto receiver tab i cant get my receiver to do anything even though it says its bound
jurt
This is what i received with the drone and what is on my beta flight
Still need a picture of the Receiver tab.
Protocol should be CRSF for ELRS
That actually looks correct. Do the channels move when you move the sticks?
Imwould also enable the telemetry toggle.
jurt
no they dont ive tried toggling it on too but still nothing
it may also be worth mentioning that when i move the drone around in the preview it is backwards but when i try to calibrate it nothing changes
Checking the FC on a quad I am building....
You should see the Aux channels that are being passed through at something other than midpoint if the RX is setup right. This board has 4.4.2 on it. Ignore my TAER1234 channel map. I use spektrum mapping since I started out running spektrum many years ago. Keeps all my flyers consistant.
If I turn my radio off, my receiver light blinks. Does yours? Maybe there is something not quite right with the bind or other ELRS parameters on the RX.
If you flashed the firmware on the FC, make sure you completely power it down. Unplug USB and battery, then plug the USB back in.
jurt
so on mine for the firmware its showing 4.4.3 and yes when i turn off my radio the drone led blinks and then when powering my radio back on it will connect again and the light will go back to solid
jurt
perhaps the flight controller is the issue cause in the preview the gyro is completely inverted
It is also plausible that the output mapping isn't set correctly on your transmitter.
Pictures of inputs, mixes, and outputs tabs from your TX might help.
Again, these are mine, but your first 4 channels should be different.
