Since the Dandy was brought up, here's the MM Dandy I built for my dad a year or two ago (green & silver) next to my MM Switchback Sport. At first glance they look completely different, I consider them non-identical twins.
They are both 4 channel (with the wings shown) and use all the same electronics.
They both allow the builder to swap wings for completely different flight styles.
They use the exact same wing although the Dandy mounts the servo on top of the wing while the Switchback mounts it to the bottom.
The fuselages are designed and built in a similar manner, but the Dandy puts the wing on top while the Switchback has it on the bottom, so the battery goes in the bottom of the Dandy and the top of the Switchback.
The Switchback layout leaves room for the canopy.
Tail surfaces on the Dandy are simple sheet design while the Switchback uses the laser cut sticks to build up the surfaces.
At the time of this picture, the Switchback has already had major nose surgery after going head-first into a frozen-solid snowbank. It took a couple hours to patch in some new balsa and re-cover it, but looking at it now you can't tell it was ever crashed. Not long after the picture my dad did the same to his Dandy, and today only he and I know it was damaged. I wasn't there when he crashed it and he didn't tell me about it until after we met at the field and I was done flying it. I'd have never known!
