I'll let @nerdnic chime in with a definitive response, but I think the firewall mount area may have some wiggle room based on what motor setup you are using. Different motors may require the firewall to be installed further forward or aft a bit. I know I beefed up the area around my firewall with a little foam doublers right behind the firewall. I'm on my mobile now but will check the laptop for pictures tomorrow.
I'll say this... I miss this plane. It flew so well and was so much fun. I should have been smarter with the wiring and taken into account the amps pulled by each motor and ran a pair of xt90 connections to two batteries (or slapped castle connectors in). The Dean's connectors failed and I melted a bunch of shielded wire on the crash that did her in. 150+ sustained amps on Dean's connectors isn't a good idea :-( If you're running a monster setup on her make sure you account for that with your wiring.
You're build is looking great! I'm eager to see more of these in the wild!
