No connection from my goggles. BetaFPV
Beta
I'm relatively new to flying and bought myself a BetaFPV Cetus X kit recently, it worked for about a month and a half. However, today I was out flying and my headset randomly cut out. Now the goggles will not find the signal that my drone is on. When I scan channels, it shows that all channels are free. Before there used to be at least one or two that were full (or being used), please help! All I see is static.
My kit:
C04 FPV Camera
25-400mW VTX
VR03 Goggles
LiteRadio 3 Controller
ELRS, Frsky Reciever
Check the VTX antenna. Make sure it is not cut/broken/deformed/etc.
Make sure your VTX is powered up, and that no connectors are loose. Are the lights on?
Make sure you don't have the VTX in Pit mode.
Pictures of your gear would be helpful.
Beta
Where do i check the VTX cable? Lights are on.
Beta
Update: I took the drone apart and found a loose wire, which seems to have been the issue. I believe this was my VTX cable. Thanks for the help LitterBug.
