BellyUpFish
OK, long story short, my Naze32 has what appears to be a dead Pin #3.
So, I ran a custom mix and got Pin 5 replicating pin 3, so I'm all good there.
I was following the Flite Test Naze32 setup video and at the point where I calibrated all the ESC's via the motors page in CF, (I think this is where it happened) I lost the power to my receiver.
I just doubled checked the receiver is working via other power methods and it does indeed power up, will bind, etc.
I'm attempting to go PPM out of a DX8 to an Orange 615X. I've got a single pigtail coming off the Naze32 at GND corresponding to ground, * corresponding to positive and the "1" pin corresponding to signal on the pig tail.
I'm also running F-12A Fire Red ESC's with 5v BEC's.
I am able to power the quad up via Cleanflight and check motor settings. I have CF configured for PPM out of the board.
Why did my power all the sudden drop out of the Naze32 to my RX?
I'm about to just tap off pin 6 for 5v power.
My current settings:
# Cleanflight/NAZE 1.9.0 May 31 2015 / 13:17:47 (98f7549)
# dump master
# mixer
mixer CUSTOM
cmix 1 1.000 -1.000 1.000 -1.000
cmix 2 1.000 -1.000 -1.000 1.000
cmix 3 1.000 1.000 1.000 1.000
cmix 4 1.000 1.000 -1.000 -1.000
cmix 5 1.000 1.000 1.000 1.000
cmix 6 0 0 0 0
# feature
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -ONESHOT125
feature -BLACKBOX
feature RX_PPM
feature VBAT
feature MOTOR_STOP
feature FAILSAFE
# map
map TAER1234
Thanks guys
# dump master
# mixer
mixer CUSTOM
cmix 6 0 0 0 0
# feature
feature -RX_PPM
feature -VBAT
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -3D
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -ONESHOT125
feature -BLACKBOX
feature RX_PPM
feature VBAT
feature MOTOR_STOP
feature FAILSAFE
# map
map TAER1234
Thanks guys
