Wizard X220 betaflight 3.1.6 failsafe issue
Kaine83
Crash test dummy
For some reason I can't get failsafe to kick in correctly. I've just flashed the latest betaflight and set it up per the Joshua Bardwell tutorial on YouTube.
Instead of cutting out on TX loss, it seems to gradually spin up to full throttle.
I'm using an FS-i6 TX with an FS-iA6 RX (all channels set to Failsafe OFF on the RX via the TX menu).
Here's my dump from Betaflight: Anyone able to help?
CLI
# dump
# Betaflight / SPRACINGF3 3.1.6 Feb 21 2017 / 14:44:08 (1fd502c)
name -
resource BEEPER 1 C15
resource MOTOR 1 A06
resource MOTOR 2 A07
resource MOTOR 3 A11
resource MOTOR 4 A12
resource MOTOR 5 B08
resource MOTOR 6 B09
resource MOTOR 7 A02
resource MOTOR 8 A03
resource MOTOR 9 NONE
resource MOTOR 10 NONE
resource MOTOR 11 NONE
resource MOTOR 12 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 A00
resource PWM 1 A00
resource PWM 2 A01
resource PWM 3 B11
resource PWM 4 B10
resource PWM 5 B04
resource PWM 6 B05
resource PWM 7 B00
resource PWM 8 B01
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A14
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 B05
resource SERIAL_TX 12 B01
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A15
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 NONE
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 B04
resource SERIAL_RX 12 B00
mixer QUADX
mmix reset
servo 0 1000 2000 1500 90 90 100 -1
servo 1 1000 2000 1500 90 90 100 -1
servo 2 1000 2000 1500 90 90 100 -1
servo 3 1000 2000 1500 90 90 100 -1
servo 4 1000 2000 1500 90 90 100 -1
servo 5 1000 2000 1500 90 90 100 -1
servo 6 1000 2000 1500 90 90 100 -1
servo 7 1000 2000 1500 90 90 100 -1
smix reset
feature -RX_PPM
feature -VBAT
feature -INFLIGHT_ACC_CAL
feature -RX_SERIAL
feature -MOTOR_STOP
feature -SERVO_TILT
feature -SOFTSERIAL
feature -GPS
feature -FAILSAFE
feature -SONAR
feature -TELEMETRY
feature -CURRENT_METER
feature -3D
feature -RX_PARALLEL_PWM
feature -RX_MSP
feature -RSSI_ADC
feature -LED_STRIP
feature -DISPLAY
feature -OSD
feature -BLACKBOX
feature -CHANNEL_FORWARDING
feature -TRANSPONDER
feature -AIRMODE
feature -SDCARD
feature -VTX
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature RX_PPM
feature VBAT
feature FAILSAFE
feature CURRENT_METER
feature RSSI_ADC
feature BLACKBOX
feature AIRMODE
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
map AETR1234
serial 0 1 115200 57600 0 115200
serial 1 32 115200 57600 0 115200
serial 2 64 115200 57600 0 115200
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 9
mode_color 5 1 11
mode_color 5 2 2
mode_color 5 3 13
mode_color 5 4 10
mode_color 5 5 3
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1900 2100
aux 1 1 1 900 1100
aux 2 2 1 1400 1600
aux 3 0 0 900 900
aux 4 0 0 900 900
aux 5 0 0 900 900
aux 6 0 0 900 900
aux 7 0 0 900 900
aux 8 0 0 900 900
aux 9 0 0 900 900
aux 10 0 0 900 900
aux 11 0 0 900 900
aux 12 0 0 900 900
aux 13 0 0 900 900
aux 14 0 0 900 900
aux 15 0 0 900 900
aux 16 0 0 900 900
aux 17 0 0 900 900
aux 18 0 0 900 900
aux 19 0 0 900 900
adjrange 0 0 0 900 900 0 0
adjrange 1 0 0 900 900 0 0
adjrange 2 0 0 900 900 0 0
adjrange 3 0 0 900 900 0 0
adjrange 4 0 0 900 900 0 0
adjrange 5 0 0 900 900 0 0
adjrange 6 0 0 900 900 0 0
adjrange 7 0 0 900 900 0 0
adjrange 8 0 0 900 900 0 0
adjrange 9 0 0 900 900 0 0
adjrange 10 0 0 900 900 0 0
adjrange 11 0 0 900 900 0 0
adjrange 12 0 0 900 900 0 0
adjrange 13 0 0 900 900 0 0
adjrange 14 0 0 900 900 0 0
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 h
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 7 h
rxfail 8 h
rxfail 9 h
rxfail 10 h
rxfail 11 h
rxfail 12 h
rxfail 13 h
rxfail 14 h
rxfail 15 h
rxfail 16 h
rxfail 17 h
set task_statistics = ON
set mid_rc = 1500
set min_check = 1005
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 30
set rc_interp = AUTO
set rc_interp_ch = RP
set rc_interp_int = 19
set rssi_ppm_invert = OFF
set input_filtering_mode = OFF
set fpv_mix_degrees = 0
set max_aux_channels = 14
set debug_mode = NONE
set min_throttle = 1020
set max_throttle = 1990
set min_command = 1000
set digital_idle_percent = 4.500
set 3d_deadband_low = 1406
set 3d_deadband_high = 1514
set 3d_neutral = 1460
set 3d_deadband_throttle = 50
set use_unsynced_pwm = OFF
set motor_pwm_protocol = ONESHOT125
set motor_pwm_rate = 480
set disarm_kill_switch = ON
set gyro_cal_on_first_arm = OFF
set auto_disarm_delay = 5
set small_angle = 25
set fixedwing_althold_dir = 1
set reboot_character = 82
set serial_update_rate_hz = 100
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_wp_radius = 200
set nav_controls_heading = ON
set nav_speed_min = 100
set nav_speed_max = 300
set nav_slew_rate = 30
set beeper_inversion = ON
set beeper_od = OFF
set serialrx_provider = SBUS
set sbus_inversion = ON
set spektrum_sat_bind = 0
set spektrum_sat_bind_autorst = 1
set tlm_switch = OFF
set tlm_inversion = ON
set sport_halfduplex = ON
set frsky_default_lat = 0.000
set frsky_default_long = 0.000
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set frsky_vfas_cell_voltage = OFF
set hott_alarm_int = 5
set pid_in_tlm = OFF
set bat_capacity = 0
set vbat_scale = 110
set vbat_max_cell_voltage = 43
set vbat_min_cell_voltage = 33
set vbat_warning_cell_voltage = 35
set vbat_hysteresis = 1
set ibat_scale = 400
set ibat_offset = 0
set mwii_ibat_output = OFF
set current_meter_type = ADC
set battery_meter_type = ADC
set bat_detect_thresh = 55
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set align_gyro = DEFAULT
set align_acc = DEFAULT
set align_mag = DEFAULT
set align_board_roll = 0
set align_board_pitch = 0
set align_board_yaw = 270
set gyro_lpf = OFF
set gyro_sync_denom = 2
set gyro_use_32khz = OFF
set gyro_lowpass_type = PT1
set gyro_lowpass = 90
set gyro_notch1_hz = 400
set gyro_notch1_cut = 300
set gyro_notch2_hz = 200
set gyro_notch2_cut = 100
set moron_threshold = 48
set imu_dcm_kp = 2500
set imu_dcm_ki = 0
set alt_hold_deadband = 40
set alt_hold_fast_change = ON
set deadband = 0
set yaw_deadband = 0
set thr_corr_value = 0
set thr_corr_angle = 800
set yaw_control_direction = 1
set yaw_motor_direction = 1
set servo_center_pulse = 1500
set tri_unarmed_servo = ON
set servo_lowpass_hz = 400
set servo_lowpass = OFF
set servo_pwm_rate = 50
set gimbal_mode = NORMAL
set channel_forwarding_start = 4
set airmode_start_throttle = 1350
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1060
set failsafe_kill_switch = OFF
set failsafe_throttle_low_delay = 10
set failsafe_procedure = DROP
set rx_min_usec = 885
set rx_max_usec = 2115
set acc_hardware = AUTO
set acc_lpf_hz = 10
set accxy_deadband = 40
set accz_deadband = 40
set acc_unarmedcal = ON
set acc_trim_pitch = 0
set acc_trim_roll = 0
set baro_tab_size = 21
set baro_noise_lpf = 0.600
set baro_cf_vel = 0.985
set baro_cf_alt = 0.965
set baro_hardware = NONE
set mag_hardware = NONE
set mag_declination = 0
set pid_process_denom = 2
set blackbox_rate_num = 1
set blackbox_rate_denom = 2
set blackbox_device = SPIFLASH
set blackbox_on_motor_test = OFF
set magzero_x = 0
set magzero_y = 0
set magzero_z = 0
set ledstrip_visual_beeper = OFF
set displayport_msp_col_adjust = 0
set displayport_msp_row_adjust = 0
profile 0
set gps_pos_p = 15
set gps_pos_i = 0
set gps_pos_d = 0
set gps_posr_p = 34
set gps_posr_i = 14
set gps_posr_d = 53
set gps_nav_p = 25
set gps_nav_i = 33
set gps_nav_d = 83
set yaw_p_limit = 500
set pidsum_limit = 0.500
set d_lowpass_type = BIQUAD
set d_lowpass = 100
set d_notch_hz = 260
set d_notch_cut = 160
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_thresh = 350
set anti_gravity_gain = 1.000
set setpoint_relax_ratio = 20
set d_setpoint_weight = 100
set yaw_accel_limit = 10.000
set accel_limit = 0.000
set iterm_windup = 50
set yaw_lowpass = 0
set p_pitch = 58
set i_pitch = 50
set d_pitch = 22
set p_roll = 44
set i_roll = 40
set d_roll = 20
set p_yaw = 70
set i_yaw = 45
set d_yaw = 20
set p_alt = 50
set i_alt = 0
set d_alt = 0
set p_level = 50
set i_level = 50
set d_level = 100
set p_vel = 55
set i_vel = 55
set d_vel = 75
set level_sensitivity = 55
set level_limit = 55
rateprofile 0
rateprofile 0
set rc_rate = 125
set rc_rate_yaw = 120
set rc_expo = 0
set rc_yaw_expo = 0
set thr_mid = 50
set thr_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 10
set tpa_breakpoint = 1650
makattack
Winter is coming
Hiya Kaine83! Welcome to the FT Forums.
What RX are you using? Usually, the failsafe functionality is dependent on how your RX reacts to a dropped connection and not all of them are the same, as it depends on the manufacturer. You might google your manufacturer and RX model for failsafe setup to check on it. You will then need to setup *flight failsafe to work in conjunction with how the RX handles it (either throttle goes below a certain value, or PPM/PWM signals stop).
Kaine83
Crash test dummy
#3
Thank you very much. I was trying to get the failsafe to be managed through Betaflight, but by doing what you said I've got it working fully managed by the TX/RX correctly now.
Why do people use the betaflight failsafe settings over the TX/RX way? are there advantages or side effects to either?
At least I know I can fly safely now. Shame it's raining!
makattack
Winter is coming
Great! Glad to see you have it sorted out mostly.
As for your question why there's a separate *flight failsafe setup/configuration, well, the short answer is: flexibility.
Without going into all the different permutations, you can think of the *flight failsafe setup as a more advanced failsafe setup. The typical RX failsafe is either to "drop everything" or "keep on with the last command."
If you want flexibility to configure failsafe to say, enable a GPS return to home mode, or auto-land, or adjust the timing of the failsafe so that a momentary loss won't trigger it, then you need to adjust all the various options in the *flight failsafe setup.
