nevenelestate
No Agenda FPV
Nice builds. After fling both your Mini-Spear and 70% Versa blunt, how would you say the two compare? Any noticeable difference in low speed performance?
Thank you.
I flew the 70% BN Versa with 1300mAh batteries and with 1806 motors, so it's a little hard to compare the heavier Mini Spear directly. I think the all around heavier weight of the MS might give it a slightly lower glide ratio, but it still will glide very well even with no motor. I still have the problem of properly lining up for a landing and then over shooting where I wanted to land because the MS just wants to glide along. I have always seen this with the wings I have built, the full size BN Versa being the best at just floating and floating and floating.
I believe I was only getting around 3min flights from the Mini Versa, I can easily get 7mins with the Mini Spear running 2200mAh batteries. And with the OSD now I will be able to accurately track what battery I have used and get the longest flights possible.
*While typing this up I just remembered that I have a 70% BN Versa, that my buddy built, in my garage. I will try to remember to bind it up and then take it out next time I go flying again. I think it will be tough to fly the MS with 2205 motor and then step down to the 1806 on the MV, but I'll try it out. Maybe I can even get some video of low slow passes or something...I'll try to remember.
