I received an electrohub kit for Christmas. Over the past few days I have built my electrohub, had my first flight and first crash following an out of control encounter with a tree... 2 broken props and 2 split booms later I decided to check over everything to make sure it was my terrible pilot skills and not anything else that caused me to crash.
I have found just one thing that seems off to me in the programing for my flip 1.5 that I can't seem to resolve. When I arm my quad and give it minimum throttle 3 of the 4 motors go to the min throttle setting but the left rear goes to a higher throttle. I have calibrated my ESC's and the accelerometer and can not come up with any reason why this one motor goes to a higher throttle. I have attached pictured on the MultiWiiConf showing the left rear with a too high throttle. Any help on this would be greatly appreciated.
The only other question I have is about arming and disarming with throttle/yaw. I have a DX5e and thus can not make some adjustments on my radio. I have adjusted the MINCHECK and MAXCHECK values to match my radio so that everything should function normally. I am able to arm my quad with the throttle all the way down and the yaw full right however when i give no throttle and yaw full left the quad will not disarm. Any ideas why this might be? I have been using the AUX1 switch to arm and disarm as a work around for this but would prefer to just throttle and yaw if possible. Attached below is a screenshot of where i changed the MINCHECK and MAXCHECK values.
Thanks in advance for any and all help! Sorry if these are really simple or stupid questions but like i said, I'm a noob.
