Hello,
I am using the ntm series 28-36 1400kv motor with a prop combination of 8*3 and esc 50A...I am using a 50A fixed winf fromHBK. The problem is when I am flying with the motor it suddenly stops in air....when I check every thing I found that every thing was fine and tought that the battery might got gone...But no..After keen observation I found that when battery voltage reaches to 10v the motor slowly decreases...When i replace a new full charged battery it works fine. Can any one say me what would be the problem?? When i changed the esc the problem still persists, And also if i remove the prop and run the motor it works with 10v and again when i replace the prop it moves faster first and slowly comes down again...can anyone say me whats the problem?
