Ronsplanes,
Welcome to the forum.
When choosing a motor for your plane the first option should always be to find the same or similar model to yours and see what they are using. Often there is nothing new under the sun.
If you can’t find this information then your next step would be to use some of the common rules of thumb to determine which motor to use. A most useful “rule” is the watts-per-pound approach which works well for most situations. Here is a version of the rule;
- Less than 50W/lb - very lightweight / low wing loading slow flyer.
- 50 to 80 W/lb - light powered gliders, basic park flyers and trainers, classic biplanes and vintage ('Old Timer') type planes.
- 80 to 120 W/lb - general sport flying and basic/intermediate aerobatics. Many scale (egwarbirds) planes suit this power band.
- 120 to 180W/lb - more serious aerobatics, pattern flying, 3D and scale EDF jets.
- 180 to 200+W/lb - faster jets and anything that requires cloud-punching power
Using this rule I would suggest targeting 120 watts per pound (W/lb) to meet your desired flying characteristics.
Assuming an all up weight (AUW) of 2 lbs when battery, ESC, and motor are installed, you will be looking for a 240 watt motor.
Looking at the FT store you will see that this
Emax motor and this
FT Radial motor fit your needs well if you read the specifications and performance figures for each motor. Going with their suggested props should also work well for your needs and you should minimally have a 30A ESC for your setup.
I have not used the Emax motor but have been very happy with the quality and performance of the FT radial motor on similar planes with respect to weight and wingspan.
Of course there are many vendors with many motors to choose from and you can use the specs of the FT motors above to comparison shop.
Best of luck!
