It is nearly 0430 local, and I'm still at it. I got the SE5 done to the point I was putting on the striping, and I noticed that the top wing was not centered. I have no idea what happened, it seemed perfect when I glued everything together. Regardless, It was way off. Major surgery time.
I had to cut the cabane struts free from the turtle deck, which destroyed the turtle deck. I cut the glue at the top of the cabanes, so I could change the angle of them. With all that I managed to fold one of them, and had to add braces. I added angle braces from the fuse to the top of the outer struts to center the top wing and had to work patches for the turtle deck in between everything to so the cabane struts had something to glue to.
I've got some weights left over from my son's Pinwood Derby days, and I've got 21grams of weight strapped under the nose. The nose still doesn't drop below the tail, when I balance the plane on the CG, but It feels heavier in the front than the back. We'll see how she flies.
Then I found out my matched motors weren't matched, and after much comparison and head scratching I decided to pull the F Pack rotary from my DR1 and let my son maiden with it. I've already got another on order for the Mini Scout, and we'll use those two motors for combat.
So I figured I'd see how the DR1 did with a 1000kv motor and a 9x45 prop. Sounded like fun. Only once I got all the motors swapped around and plugged up and whatnot, the set screw on the 1000kv I got from YoungRC stripped out when I was tightening the propellor down, and now that motor is trash. That motor never even flew. I'd just taken it out of the box.
So back into the stash, and I've got a motor without markings that doesn't spin as freely as a 2300kv, but doesn't seem as tight as 1000kv. So I wired that up and stuck a 9x45 on it, and we'll see what happens.
I got the same weight set up ready for the DR1 as I've got on the SE5, only the strap won't work because of the cowling, which I just reattached. So I'm about to try to poke the skewers through the cowling from the inside, so I can cut some longer skewers that will go outside of the cowling and hold the strap in place.
I needed a break and it seemed a good time to update the thread. Why all the manic overnight build and repair? We're supposed to maiden the SE5 this afternoon! It was going so smoothly, right on track. Then BOOM! one thing after another after another. I'm determined. These darn planes are going to the field!
Ironically it might be too windy to actually fly the DR1 or the SE5. Forecast is iffy, and we won't know until we get there. I love this hobby.
