Looking forward to the video of that, UndCon!
I can tell you this video is booring
This is a screenshot from the video...recorded with GoPro in r2 mode.
I took a walk around block - the same path as in my Cloverleaf test and the FrSky test
This time I used the servo test programming for Er9X - It continuously moves the servo from end to end.
If I drop the signal the failsafe kicks in after a predetermined value in
OpenLRSng
(default is ~2secs)
I left the receiver on a table with a dipole connected and my route goes in various directions around the antenna.
The summary...
I did hear a few faint beeps from the TX module, this indicates a few dropped packets but the failsafe never kicked in. I could not trigger dropped packets by moving antenna around during my walk.
At most I had 3-4 buildings between me and the RX - remember that I walk on a street and the RX is lying on a table - far from optimal when we talk radio waves.
Imagine the RX being mounted on a plane...
I have to do some serious range checks with the Bixler...
I will do this by programming waypoints further and furhter away from me in Arduplane software.
If I drop signal, failsafe will kick in and engage RTH.
I assume I will have greater range on 433 than on my 1.2Ghz Videolink.
Only tests will tell how far I can go now...
//UndCon
