I’ve had the same issue on several planes (the worst was on the mm ft22) and I think it is because of the motor torque. If the wingspan is too small and the motor too big, when you’re going slow there isn’t a lot of airflow over the wings to stabilize the planes, and so the torque of the motor makes to oscillate from side to side. But once you get up to speed it is finally able to stabilize. I’ve designed a few planes and I’ve found that planes with an actual airfoil and not just a piece of foam don’t tend to do it. Idk if there is an actual reason for that or if I just got lucky, but I’d try adding an airfoil to your wing or just constantly fly fast 🤣🤣
Also making the whole wing bigger should work as well, but if you want that size of plane try id try an airfoil
