kdobson83
Noob question. How does one determine if an esc is overheating? I am flying a ARC Pirates Eazy, fairly small aircraft, smaller that the TT. I am running it on a DYS Samguk 2206 2400kv motor with a 5x4x4 prop and a 30a Emax BL Heli esc. I maidened it the other day on 3s and it flew awesome. Towards the end of the 2nd battery, it started to sputter, like it was misfiring and went down to maybe 20% power. I didn't think to much into it as i was at the end of the battery anyway. Well, today, i decided to try it on 4s. But this time, it did the exact same thing but at less than half the battery used, and did it on all 3 batteries. I landed it, felt everything for heat, everything was cool except the esc. It was a tad hot but i could hold it easily in my had. After waiting a minute, i threw her back out and it flew fine for about 30 seconds and started doing it again, sputtering around not going over 20% throttle.
Now, looking at the specs, the motor on 3s with that prop only draws about 19a. With a 30a esc, it shouldn't have any problem at all. Heck, even on 4s its only drawing about 28a. With an esc that is 2-4s compatible and does 30a continuous and up to 40a burst, how would this cause me issue? In theory, i should be able to run 4s with that prop and full throttle till the battery dies before i have issue.
Does this sound like the esc is overheating? If so, is there a solution to this issue other than cutting vents into the fuselage?
