bmarvin2222
I built the sparrow with a Emax MT1806-2280kv using the BL Heli 12amp ESC. I'm flying at about 2/3 throttle for 2 or 3 minutes, then it starts lagging and losing power. I bench tested with the wing off and felt the ESC and motor... both really hot. I just replaced the ESC because the prior setup was doing the same thing (losing power). I used to get 9 minutes of flight time with NO problems... wondering if I just need to replace the motor. Any suggestions?
Note: I have the ESC mounted inside the plane, but that is same location as when it ran fine (9 min. flights).
