It's taken me all afternoon to get those two together. I'm hoping to save the next pilot a bit of headache.
First though, if you're a new pilot? Spend the $14 and get the sim. This is what I got:
https://www.amazon.com/dp/B07HL7QPGR/?tag=lstir-20
$14 dollars and free shipping from a U.S. warehouse. It is absolutely amazing how much I suck at flying RC aircraft. I learned that with the sim today. No, it's not a perfect, real world experience, but I have no doubt that this thing is going to save me a TON of hassle and heartbreak.
Plus it's a whole lot of fun. When I got tired of crashing my TT, I crashed a half-dozen other aircraft. My son and I spent the evening passing my trans back and forth. The turbine powered A-10 was a blast!
If you get the one I got, or similar, it's version 5.0.b and it won't support the new models. When the program starts you'll get a pop-up saying there is a new launcher available. I have been unable to get that to download. Click on "No" and you get another pop-up saying there is a new version of the program available. Click on "Yes" and let it it's do it's thing. You now have version 5.5.l which supports the new models.
If you are using the models from the first page of this thread:
https://forum.flitetest.com/index.php?threads/flitetest-in-phoenix-rc-model-index.27096/
You need to open File Explorer and navigate to where the instructions say to. I had to create the last two folders, as they simply weren't there. Download the zip file to somewhere easy for you, and copy the contents into the final folder. When you next launch Phoenix, the new plane is under "Airplanes" "Electric" in the Change Plane dialogue. It will be a green font and easy to pick out.
If you are using the later models from rickp, they are packaged differently. When you first start Phoenix, cancel through the new launcher pop-up. On the right hand side of the window you'll see a button that says "Advanced." Click on it and in the drop-down you'll see "Install an Update." Click on that, navigate to where you put the .pkg file, and select it.
That plane will also show under "Airplanes" and then "Electric" (assuming the plane is electric. I haven't tried the others, yet) also in a green font. Once you've got all that you not only have access to the FT foamies that JohnRambozo put so much work into, you've also got access to what's in this link from rickp:
https://www.rcgroups.com/forums/showthread.php?2382571-User-Built-Models-for-PhoenixRC&perpage=20
I haven't counted, but there must be 200 models there! Wow! If you have questions, post them here and I'll try to help. Keep in mind I'm usually only on the forum late at night East Coast U.S. time. Also, I'll be here a lot less for a little while. I've got skills to master and a sim to help me do it.
The Journey Continues.
