SSgt Duramax
I see tossed around that some plane or trinket is good for a beginner, intermediate, or advanced pilot. How do you determine what your skill level is?
Is it what kind of plane you can fly? What bad tendencies you can deal with? If you can fly a plane that is a flying brick that does nasty tip stalls, does that make you an advanced pilot?
Is it what maneuvers you can pull off? Does being able to fly inverted nearly dragging your v stab across the ground and do 3d maneuvers in a trainer the gold standard of a good pilot?
What about setting up your equipment? I know that is half the battle, and in theory you could be good at setting up or building or whatever, and not be able to fly worth a darn.
For instance, I consider myself an intermediate pilot. I can do aerobatic maneuvers, safely land 95% of the time. Usually keep control or recover if something silly happens, fly some relatively twitchy planes, and some relatively fast ones. I'm still not comfortable with my really fast plane in a small area, but can manage.
I feel like each "level" if you will covers a large swath of things. A "beginner" may be someone struggling to fly a 3ch, or someone that can pretty successfully fly a 4ch plane on their own.
What do yall say?
What do yall say?
