Monte.C
I do think I understand the basics in a very general way. The first number represents the physical size of the motor - this varies among manufacturers but can be used to compare one motor to another in a relative way. The second number is a representation of RPM per rotational force applied. I guess. Can you help me translate this to a real world application?
I have two motors, both Emax. A 2213-935KV and a 2206-1500KV.
I had a stik/trainer that I ran on an 1806-2280KV A-type motor, based on comparison with the Mighty Mini series planes. It flew great on 3S, seemed just right for me, just learning to fly. The plane I'm setting up now is comparable to that first plane but a little bigger. 34" wingspan and pretty light, certainly not heavy. It has lots of wing.
Since this is just a little bit more plane, and based on reports here on the forum, I'm thinking it won't hurt to go up a size. (My throttle thumb isn't in the habit of getting stuck in the full-on position.)
The first number for these motors is very similar, but they have very different dimensions. The KV ratings are different. For real: Are these overkill for my plane? Do I need to step down to a 20XX-size motor? Which might be more suitable? Is it like... one is "hotter" and one is more torque-y? The 2206 runs faster, the 2213 is more brutish, like a lower gear. This doesn't give me a solid answer. I'm not looking to go real fast. Can anybody help me understand better?
