Johan
Only port 1 needs to be connected to a UBEC, but the remaing 7 are routed nowhere. if you try to draw off, say port 8, you will be grounded but you will get no power from the other 3 ESCs. you *could* pull out one of the ESC's power lines (from ports 2-3, NOT port 1), and connect it to the boscam power line, but that's a messy connection.
Crafty Dan, are you sure? I know that if you look at the back of the KK2, the middle (+5V) pins look isolated, but if you connect a Resitance meter between the +5 of each of these ports, you'll measure 0 Ohm, meaning the +5V of ports 2 to 8 are interconnected.
On my tri I have :
1 ESC (with 5V) on port 1, this powers the KK2 obviously and through that the transmitter
1 ESC (with 5V) on port 2,
1 ESC without 5 V on port 3
1 servo on port 4, which gets its 5V power from the common port2 - port8 5V connection ....
This is how it is in the KK2 manual:
"The M1 connector must always have a ESC connected, because this ESC will be the only one that supplies the FC with 5V power. This ensures stable power to the FC.
The M2 to M8's 5V power pin is connected together, and any servos here will be supplied by any ESC'sconnected here. There is not necessary to cut the 5V (red) lead on any ESC unless it has a SwitchingBEC."
Since my ESC's are SBECS, I folded back ont of the remaining +5 cables
