quorneng
With the wing joined together a start is made on how to install the batteries, ESC and rx in the wing.
A rough guestimate of the required CofG made it clear the battery(s) would have to go as far forward as possible which meant right into the wing leading edge at the root.
This suggested a twin arrangement either side of the central rib. The Depron battery boxes were made big enough to handle a range of sizes. The batteries would be inserted via a substantial hatch.
Note the 'magnet wire' used to connect the motors to the tiny opto 'Little Bee'20A ESCs. It is much lighter than silicon insulated flex.
Each ESC is supported vertically in a small printed holder to aid cooling.
An additional mount is added for the 8A UBEC that powers the rx and servos
For safely the motors are wired up so the inboard and outboards pairs can be supplied by their own battery.
As most of this will not be accessible everything is tested carefully both singly and all together.
The short test of all four motors mounted on the wing.
I had not realised how close it was to sucking the bedspread up into the motor.
Certainly sounds impressive!
