Apart from any decoration the next problem is how to launch it hand held? A problem made worse by the fact 99% of the time I fly alone and the fuselage is far too big to hold with one hand.
On some on my other bigger planes planes I have used specific finger holds built into the fuselage positioned so the plane can be balanced with the fingers of one hand and strong enough to take the launching impulse.
The sheer size of the AN124 means the three finger holds will have to set into the underside underside, bowling ball fashion, with some internal reinforcement.
Thumb and forefinger to support the weight with a side grip. The index finger behind to provide the push.
The holes are braced with a portion of flooring.
It will still need great care as virtually all the weight is in the wing on top of the fuselage with only a few light weight frames and Depron keeping them in position.
The AN 124 fully decorated and taken outside for the first time.
The inside of the fuselage seems to go on for ever and with absolutely nothing in it.
Big, delicate and likely to be a bit powered the maiden could well be a one off, never to be repeated event.
