Anyone else out there have a Graupner radio that can help me out with programming flaps on my E-flite Super Cub 25e? I have gone through the manual, using the Quick Setup menu. Here is what I want to do:
1. Ailerons on 2 separate channels so I can program differential, if needed. Cubs are notorious for adverse yaw.
2. Flaps on single channel via Y harness using two-position switch, S6.
Setting for ail/flap under the quick menu includes, 1 ail, 1 ail/1 flap and 2 ail/1 flap when tail type is set to "normal" and motor at C1 is set to idle rev. I take this to mean the following:
1 ail = both ailerons on single channel via Y harness.
1 ail/1 flap = ail same as above and both flaps on single channel via Y harness.
2 ail/1 flap = ailerons on 2 separate channels/both flaps on single channel via Y harness.
After playing around with this, I am not sure I am interpreting this correctly. When set at 2 ail/1flap, the flaps and ailerons operate in unison but I have no flap function. Its like flaperons with only the"erons" part.
Does anyone out there speak Graupner? Balu??? Do you speak Graupner since they were bought be a Korean company? LOL!!!
This is no prob in my er9x radio. Ailerons will be on channels 1 and 6, and flaps on whatever channel I assign to the 3 position switch. Piece of cake. (I do realize that aileron is channel 2 on Graupner).
Thanks for any help you can offer!!!
