I use the suppo 2208 and these prop adaptors,
the silver bullet there in the pic are compression adapters. Put the prop over the threaded part, then the silver bullet, then use a small screw driver or allen wrench thru the hole in the bullet. Hold the prop, tighten with the tool you used in the hole. Tighten until snug, not overly tight. This will cause both parts of bullet to clamp into the plastic of the blade and hold securely.
I have heard of these coming off in flight, so I always check them before a flight to ensure they are still tight. I have not had one come loose yet. Hope this helps.
