Hello All,
I am in the process of drafting up a set of plans for a Navy P3 Orion and I have run into a scale problem. Hopefully some of the designers on here can chime in.
At the design scale from the wing root to tip is 46 inches. This is not my intended model scale, I am shooting for approximately 50-60 in wingspan total. Using the numbers I have now, the distance from the root to the inboard nacelle is 10.48 in rounded to 10.5 and between nacelles is 14.65 in rounded to 14.5. If I halve the distances to get close to the intended model scale, the distance between nacelles gets uncomfortably close, leaving just enough room for a 6 inch prop.
I am trying to hold to the Flite test power pack size and this spacing is too close for a power pack C -10 in prop. Does anyone have experience with running 4 smaller props on a larger scale model?
Thanks In advance
Joe
Thanks In advance
Joe
