Im not an expert by any means , first thing I would check is your board and radio settings to ensure you motors are turning at full throttle.
If you have some gains turned down on the kk board too low it will effect throttle , and I have learned that I have to have the throttle set at 100% on the kk board .
ON my orangerx radio I can look at my stick movements , which I do before a flight to ensure I have proper range of movements there too.
When I built my quad I found motor/prop combinations to be confusing so I opted for a power pack that flite test recommended for the knuckle quad , which is what i built , and I am very happy with the power my quad has.
When I was designing my quad I read many articles on how much lift to have to get the quad to do what you want it to do.
Here are some rules of thumb that I have found to use when trying to determine what motors you should use.
Motors range from 800kv to 3000kv ---
lower kv motors use large props that turn slower , but are more efficient. 10" to 12" props
faster turning motors use smaller props that are less efficient , but more responsive to turns , throttle. 5" to 6" props
mid range motors--1900kv--use 7" to 8" props efficiency and response is in between the other types.
From what I can tell slow kv is something around 800 to 1200 kv , this is not exact numbers , simply a best guess from what I've learned.
Motor specs should recommend props sizes for you , if not , choose a better documented motor.
http://www.flybrushless.com/motor/view/454
I use this site to see how much lift my motor/prop combination will generate. The info is not exact , but it is useful.
Then I used these rules of thumb ::
Goal is to hover at 50% throttle
2.2 x weight (of quad or tricoptor) 2.2:1 thrust /weight ratio, is the minimum amount of thrust needed to have a well flying machine.
So a 1000g quad should have 2200g of lift total. 4 motors on a quad , so each motor should be capable of producing 550g of lift.
3 x weight of the quad, 3:1 thrust ratio, to have an good acrobatic quad .
another general rule I found is watts of motor x 3 = thrust output of motor
Looking at your motors , they are supposed to use 10" props , slow turning , which is not what you want for a 250 quad. Which is what RichB was telling you.
Hope this helps and that you get your power problem fixed !
Take care
