If you flash the radio to OpenTX, you can change the low voltage alarm value. The stock firmware can't do that. If you go from the stock battery to a higher-voltage one (such as a 3S LiPo), you can use a voltage divider to make the alarm have the correct value again. But going from the stock battery to a lower-voltage one... I'm not sure you can fix that except in firmware.
