Radio brownouts & Reboots - RX, ESC, Servos, or do I just need BECs?
I need some help figuring out a problem I am having with my ESCs/Servos/Radios. All configurations discussed below are using FrSky S6R RX and 3S Lipos.
Short and sweet version: 1) When should I move to using a dedicated BEC vs the one built into the ESC? 2) Should I be freaked out about flying my HK Walrus 2M motor glider that has a full boat of 6 servos on the HK-supplied ESC? 3) Did I buy a bunch of bad servos, bad receivers, or bad ESCs? 4) How do I go about figuring out the answer to #3 if it isn’t a cut and dried answer?
Longer Version:
I’ve been having mixed success on my journey since re-entering the hobby about 6 months ago. When I got back in, I bought the following as my go-to components when building new planes, which have served me quite well up until about 3 weeks ago:
I was going to throw out the LHI ESCs as junk when I decided to mix things up a bit to troubleshoot further. If I tried the small (undersized IMO) spider 18A ESC in the LittleStick, the problem was much more intermittent (but still kept happening). In desperation I pulled out my 1 and only stand-alone BEC (rated 3A @ 5V) and the problem went away on the LittleStick. I have more BECs coming to see if that becomes a better workaround. But here's the thing: Every single ESC I have says it is rated for 3A at 5V, which is exactly the same rating as the external BEC I used to 'fix' the LittleStick.
I’ve already stated my questions, but the biggest/burning issue for me is “Have I been lucky that I haven’t cratered by Walrus yet?” I ask this because I pile-drove my Bix3 shortly after takeoff on a windy day. I wrote it off as a stall as I entered the downwind leg after takeoff or “pilot error plus flying in too much wind”. But now I am seriously wondering if maybe I had a brownout and my radio rebooted at a critical phase of flight. It had 6 servos (2 flaps, 2 Ailerons, elevator, rudder) and I routinely flew it with the flaps setup as flapperons. At the time of the crash it was in that mode and I was flying fairly slow right after takeoff with about 30 degrees of flaps. It was using a Turnigy 30A Plush ESC, which (until now) I have thought were rock-solid. I am obviously concerned because my Walrus is basically a higher performance version of the Bix3 with the same HXT900 servos / plush esc combination in use.
Sorry for the longwinded post, but I wanted to get as much info out there as I could up front, in the hopes I could get some answers in time for next weekend’s flying sessions!
TIA for advice, suggestions!
Longer Version:
- 6x Turnigy Plush 30A ESCs
- 8x Turnigy and Hextronic brushless motors
- ~24 HXT900 (9g) and ~10 HXT500 (5g) servos
- 5x Frsky S6R receivers (contains integrated gyro)
- 4x additional Frsky S6R receivers (I love these, don’t see any reason to change)
- 4x no-name 1806 2300KV quad motors for Mighty Mini series planes (QUANUM BE1806-2300KV RACE EDITION BRUSHLESS MOTOR 3~4S (CW)
- 4x no-name mini ESCs to go with the 1806 motors (ZTW SPIDER PRO LITE SERIES 20A BEC F390 48MHZ ESC 2~4S BLHELI FIRMWARE)
- Several different NTM Propdrive motors 28mm (PROPDRIVE V2 2836 1800KV BRUSHLESS OUTRUNNER MOTOR) – ALSO THE 2700KV AND 1300KV VERSIONS
- 4x copycat versions of the Turnigy Plush 30A ESC - LHI 30a Brushless Speed Controller Esc Multicopter Kk Quadrotor(pack of 4pcs) Link: http://a.co/0jZZZl1
- 10 Towerpro 9g servos: TowerPro SG90 Micro Servo 2pk - Link: http://a.co/hmmUQ1Q
- 10 TURNIGY™ TSS-10HM DS MICRO SERVO 15T 2.2KG / 0.12SEC / 10G
