Radiomaster boxer / flysky receiver wont hold a bind
RossFPV
I have the radiomaster boxer and the receiver that came with my old fs-i6 and it binds perfectly fine but after a power cycle it acts like nothing was ever binded. Help?
FlyerInStyle
I was removing the bind plug without powering off, i will try this tomorrow (its almost 9:00pm for me)
same time for me. It is a probelm with flyskys, where sometimes a receiver will not remember htat it is bound if you remove hte bind plug while powered on. Only a flysky issue
My older FlySky Rx's will work great. The newer ones it will remember the bind from flight to flight, just as long as I don't switch models.
When I switch models I have to rebind the newer Rx's, the ones using AFHDS2A.
My work around, I made a remote bind plug using a servo extender on the bind plug.
Foamforce
Fwiw, I haven’t had this issue with my TX16S. I have a few different models of AFHDS2A receivers. I believe my binding procedure is to turn on the transmitter, put it in bond mode, put the bind plug on the receiver, plug that in, confirm binding, disconnect bind plug, then unplug the receiver and plug back in to confirm. I’m on the latest version of EdgeTX. Not sure if this helps.
