TheFlyingBrit
Apparently there have been issues reported with the 3.5mm jack plugs used on the Radiomaster transmitter for buddy leads. It appears the correct jack plug is a longer version than normally used on other transmitters like Spektrum.
This is the correct plug, its a 4 pole jack plug FC68124.
So now your aware, if you want to use a buddy lead on your TX16s you will need to make one of these up. If you use the std mono or stereo jack plugs you may have problems.
