Resource for RAF/RCAF insignia
For all of you out there who would like to put the correct markings on your aircraft, I found a great resource for RCAF and RAF warbirds. I've been adapting them to SVG files so they can be exported to a vinyl cutter. the files below will give you two large and two small Type A and two Type B. This is consistant with early war markings for both the RAF and the RCAF.
I made the white larger than the hole in the blue ring so you could put it down first and then the blue over that with the red dot in the center. This takes some of the exactness out of the equation when it comes to placement.
Enjoy!
http://www.vintagewings.ca/VintageN...ticleView/articleId/382/Roundel-Round-Up.aspx
