Reversing the motor direction on Cub and Scout
I have a lot of props that are "R". Is there anything wrong with reversing the motor in order to use these props? Will it just want to go right instead of to the left? this would be for a cub and scout. thanks
#3
paracodespoder is right. if it is the big scout then you should have no problem. The mini will have to have reversed thrust angle. I would recommend getting some nylock nuts to make sure you don't have any problems holding on the prop.
