Flyer Sean
Here is a 40in span DTFB Rightwing inspired wing. It hasn't flown yet but its looking pretty good. CG should be about 7.25 inches from the nose. I am planing on an hd cam and 2 2200mah 3s batteries. If your batteries are smaller or your not using a HD cam I would build it with the motor cut out larger to get the motor further forward.
The construction is the same as my foamboard spec wings. rib placement is at 1/4 of the way down the wing and at 3/4 of the way down the wing.
