BobK
Banned
Yeah I know here I go again, I have mentioned this to a few people and usually get a "whatever" response but I have to say every time I see people using only two rubber bands on their wings I just have to cringe a bit. Maybe it's because it was pounded into my head over and over again and I realize that I am used to bigger heavier planes, but take a second and think about it, what happens when you happen to grab that one bad rubber band in the package and it snaps while flying? Don't ask but I know the answer.
Anyway, just take a second and think about it, I am just as lazy and I personally hate strapping more than two rubber bands on (cripes I just built a biplane..that means I should use eight!
) but I still do, several times I have seen a plane come down with a snapped band and I can tell you it doesn't float in at all. So, just consider taking an extra few seconds and use four, I really hate to see crashes because of a simple little thing like a snapped band.
Two rubber bands strapped straight across the chord..not a great idea, the wing can shift on the wing saddle and a band can slip off the end of the dowel or skewer, or if one snaps..lawn dart.
Two rubber bands crossed of the center of the wing..still not a great idea, the wing can shift on the wing saddle and can also seesaw on the fuse, if anyone has a plane that flies horribly it just might be the reason why. You can test this by setting your plane on the ground and push down a wing tip while holding the fuse solid, especially on something like the Storch with a long wing. If it is floppy on the ground just imagine what it is like in the air, and if one snaps..again..lawn dart.
I have also seen people cheat a bit and use extra long bands, they will run them straight across the chord to the other peg then stretch them all the way over the wing again to cross them, ok..now you have the effect of using four, but if one snaps..another lawn dart.
The right way, two rubber bands strapped straight across the chord of the wing, then two more crossed over the center. The crossed bands put on after the first two lock the first two in and the wing solidly in place, and this gives you three bands left if one snaps..if two snap you still are at least fairly good..and I would toss out the rest of your rubber bands and buy new ones.
I know someone will think that four is too many and feel the wing will be mounted to solidly in a crash, that may be so but it will still give quite a bit. With my collection of different sized planes I have ran into problems finding just the right sized bands, sometimes I link two smaller ones together to make longer ones. If you use the right sized bands for the size of airplane you are golden.
I just wanted to mention this, I hardly ever see more than two bands being used here, and I am not saying you have to use four..just consider it. It is a tough lesson when the unlikely happens..I know this.
