Hai-Lee
Old and Bold RC PILOT
Recently I had someone tell me that Balsa was too heavy for use as a covering material so I set about discovering for myself if he was correct or just prejudiced against everything he had not experienced. I had been planning to remove the crinkled and de-laminating paper on a few of my favourite FT FB models and coat the foam in 1mm Balsa and then covering film as I do for my Balsa models.
So I though about what to cover and how. As I have a local club and there are almost a dozen flying examples of the same design, ((Das) Little Parkflyer Stick which has plans posted in the plans thread), I rationalized that the resultant stream of spare fuselages and wings could assist in keeping them in the air and so the test plane was selected.
For the test I have already cut out 3 FB fuselages. The first one is standard, the second has the outer paper removed and the third has absolutely no Paper on the FB. A fourth version may be completed eventually completely using Balsa but that would not be required for the exercise and therefore not included in this thread.
The weights of the resultant fuselages prior to assembly are/were:
First fuselage, Taped in clear packing tape and glued together:- 37 grams, (58 Grams with the taped tail feathers attached).
Second Fuselage, Outer paper stripped only at this time, (Not glued and no tail). :- 21Grams (a reduction of 10 Grams).
Third fuselage, All paper removed, (Not glued and no tail). :- 14 Grams (a reduction of 17 Grams, I suspect the paper on each side is of a different or grade because of the different weight savings).
Today I had a requirement for a replacement fuselage and as the first fuselage was effectively finished I passed it on to the one who required it.
With such a significant weight reduction on the third Fuselage I have started assembly and covering the fuselage in 1mm Balsa, (Medium grade), so far the added strength is incredible though I do really need to find an alternate glue as the White glue does not really like the smooth finish of the freshly stripped FB.
Some progress photographs will be supplied next time I am at this thread with perhaps some updated weight figures for the third fuselage coated in 1mm Balsa.
Next time!
Here are the pics mentioned. Sorry about the Quality!
The three fuselages cut out and weighed
Completed Fuselage 1
Balsa Sheeting Fuselage 3
Update on Fuselage 3 the coated weight with Tail came out to 50 Grams With a little lightening of the tail foam with holes. This compares very well with the taped original version, (Fuselage 1), So that leaves me a weight budget of 8 Grams for covering which is a very generous amount and I still have not tried to lighten the fuselage at all and the strength has improved out of sight. The fuselage is very strong and distortion resistant in the direction of the grain , (flight direction).
The wing is next after which I will rummage through my covering film stock and select a colour scheme.
More to come!
Started the wing and so far the weight saving is over 40 grams. Pics included at various stages of the proceedure.
Wing cut out
Stripped of paper
Edge coating
Joined together
Current progress
So far the weight reduction has been remarkable even though I left the internal paper attached. Basic film covering selected , Silver with orange and blue trim. More tomorrow if I get time.
Next time!
More to come!
Wing cut out
Stripped of paper
Edge coating
Joined together
Current progress
